Skip to main content
This version of GitHub Enterprise Server will be discontinued on 2025-06-04. No patch releases will be made, even for critical security issues. For better performance, improved security, and new features, upgrade to the latest version of GitHub Enterprise Server. For help with the upgrade, contact GitHub Enterprise support.
Troubleshooting identity and access management for your enterprise
Review common issues and solutions for identity and access management for your enterprise.
Username conflicts
GitHub normalizes the SCIM userName attribute value that is sent by an identity provider (IdP) in a SCIM API call to create each person's username on GitHub. If multiple accounts are normalized into the same GitHub username, a username conflict occurs, and only the first user account is created. For more information, see Username considerations for external authentication.
Accessing your enterprise when SSO is not available
When a configuration error or an issue with your identity provider IdP prevents you from using SSO, you can use a site admin with access to the Management Console to update your settings, or disable SAML temporarily. For more information, see Administering your instance from the web UI.
SCIM provisioning errors
Microsoft Entra ID (previously known as Azure AD) will retry SCIM provisioning attempts automatically during the next Entra ID sync cycle. The default SCIM provisioning interval for Entra ID is 40 minutes. For more information about this retry behavior, see the Microsoft documentation or contact Microsoft support if you need additional assistance.
Okta will retry failed SCIM provisioning attempts with manual Okta admin intervention. For more information about how an Okta admin can retry a failed task for a specific application, see the Okta documentation or contact Okta support.
In your instance where SCIM is generally functioning properly, individual user SCIM provisioning attempts sometimes fail. Users will be unable to sign in until their account is provisioned to GitHub. These individual SCIM user provisioning failures result in an HTTP 400 range status code and are typically caused by issues with username normalization or username conflicts, where another user with the same normalized username already exists in the enterprise. See Username considerations for external authentication.
SAML authentication errors
If users are experiencing errors when attempting to authenticate with SAML, see Troubleshooting SAML authentication.
Further reading
